ChrisJ
I just wanted to share a small bit of info I just received from Mobil via email.
According to them there is no harm in mixing different viscosity oils. For example adding a quart of 5W30 to your engine when you had used 0W30 or 10W30 when you changed the oil.
In the past I have run 0W30 and sometimes you can't find that so its nice to know there is no harm in mixing them. Of course, I would personally try to keep the second number the same. Obviously adding a quart of 0w30 to 4 quarts of 10w30 will thin it slightly in cold temperatures where adding a quart of 10w30 to 4 quarts of 0w30 will thicken it slightly in cold temperatures.
The original reason I had emailed them was I changed the oil in my generator using 10w30 M1 extended performance and ended up a hair short. I had 5w30 M1 extended performance on hand so just topped off with that. Obviously the generator doesn't care if it has 0w30, 5w30 or 10w30 but I wanted to be sure there wasn't some kind of chemical disaster waiting to happen.
