kenimpzoom
Has anyone changed to non stock spark plugs?
I only saw AC Delco and Autolite offer spark plugs, are there any others available?
i generally dont recommend running anything but factory plugs, in ANY vehicle, unless power gains reach the 25-30% mark. Spark plugs are VERY specific to there application.
I see all these add for outrageous claims of power and economy, with multi electrodes and the whatnot. Usually these things just cause more problems than anything. If you do want to upgrade, use the same factory brand, and go a range colder and see what happens.
I will look it up on the GM service info website.
GM factory spark plug GM part# 55580961
AC Delco factory replacement Part# 41–117
Now, further searching on Google, it seams that this is an Iridium Plug (as opposed to a copper one like in the aveo, which was the only gm car I know of that didnt have iridium)
Iridium plugs are pretty much as good as it gets, and they cannot be gapped. I will confirm this with parts tomorrow, but best bet is just going a range cooler if your running a tune with a few other mods and you are on it ALL THE TIME, or AutoX etc. Otherwise, I would leave it alone.
But I will check tomorrow.
The only reason I changed spark plugs was because I was jacking with the originals when the whole spark plug gap issue was being discussed. Mine all had different gaps so I was trying to re gap one and busted the tip off. I wasn't about to take the car to the dealer for that since they are a warranty nazi. lol
I went to the auto parts store and the GM part number can up with the Iridium autolites. They look exactly like the originals.
I gaped them all the same .028 I believe and it is running a lot better than it was. Before it would start spitting at high loads.
The E3's actually are pretty good in carb'd cars and yard equipment.
