Sorry but where does one hook the hoses to the catch can up?
How did you hook it up?So the catch can did not work out for the 1.8 , clean tight connections and im assuming it wasnt enough vacuum pressure at idle because it idled like crap and threw a code.
Sent from my S60 using Tapatalk
A cheap can, can cause problemsIn between the pcv connections from crankcase to can and from can to throttle body. I dont think the vacuum demand is met at idle with the can and thr length of the hose to such connections was longer than the normal route. Or the cheap can has very small connections one of the two
I would also try blocking the Tb port and venting to atmosphere
