2012 1.8L 87,000 miles..
changed thermostat and sensor after getting a p0597 code..ran 300 miles no problem..then got the p0597,p0598 and p00b6 codes and temp warning light.cleared codes...changed the radiator temp sensor and another thermostat w/sensor..ran at idle to purge system and had heat to all hoses(heater worked)..shut down let sit overnite and did a 10 mile test drive next morning..p00b6 code came up again when i restarted afterwards. reservoir is full and no leaks..any ideas??
