Read this thread. . . and ALL the links in it to get an understanding of the PCV path and system. Lot's of info and same engine as in Chevy Cruze.
http://www.sonicownersforum.com/forum/1-4l-turbo-sonic-engine-discussion/23441-psa-1-4l-pcv-system-maintenance-required.html
With that many miles, replace the intake manifold or at least check the PCV path and check valves. . yes two of them.
Other than that, check the water outlet for cracks. . . also the thermostat and hoses. Might replace the water pump as it can start leaking.
Oh. . drain and fill to Proper Level the automatic trans fluid if it has not been changed in 30,000 or 40,000 miles. Again. . . Youtube Cruze videos show how to do this. Easy if steps are observed. Drain and fill EXACTLY what you drain out. . . repeat Three Times. . . This is a very compact light duty auto trans. Fluid should be changed every 30K to 40Kiles. It gets black that quickly.
Search using Google>Sonicownersforum>1.4L
Read . . . read . . . read all that has to do with the 1.4L engine here and on the Cruze forum.
Be informed and proactive. Maintain things now before the engine blows a main seal, turbo damage, etc. $200 to $300 now will save you $$$$$ later.
I would also check/replace brake caliper/pads and a few other things. Read an online owners manual for +90,000 mile maintenance.
