Are there problems with 2013 water pumps on the 1.8 liter engine as well? Supposedly there was a recall only on the 1.4 liter engine water pump.
When these pumps "fail", what exactly fails? The water pump shaft seal, or the impeller? BTW, is the impeller made of metal or plastic?
At 30k miles I had to add about 1 quart of coolant to the overflow bottle as the level dropped. The level remained pretty much constant for the next 5k miles. Is this normal due to coolant boil off?
