jennie421
My Sonic is going on 6 years old and recently been having unexplainable issues. The dealer doesn't get an error code so we aren't able to pin point the problem and fix it.
Some of the issues are:
The door open light comes on when no doors are open and the locks won't work with the remote or manually with the button in the car. I can only get in with the key. I drive along for a bit and the light turns off, locks go up and down by them selves and are back to normal for a bit. The alarm goes off when I try to lock it once I've parked.
It has also locked itself without being on or in gear.
The interior ceiling light flickers on and off. This is a new problem as of this week.
Mylink screen has a delay coming on.
Has anyone had similar issues and know what could be causing this to happen?
Thank You
Thank You
