XFOXRACING12X
I have a 2013 sonic Hatchback 1.4 T manual with 62K on it. Roughly 6 months ago i started noticing a whine. Its entirely speed related between 25-60 mph. Faster than that and road noise drowns it out. Turning, changing gears, or braking has no effect on the noise. killing the engine also has no effect. I went to the dealer and they said they heard it but could find nothing wrong and gave it back with saying " if it gets louder bring it back" they said they checked the wheel bearings and used a stethoscope to try to locate the noise but were unsuccessful. Furthermore, now the noise is louder and i've noticed there sounds like a bearing comeapart in the transaxle case. Has anyone else had this same issue? And was a transaxle bearing the culprit?
