JesusTheAgnostic
So today I was mad at my girl for reasons and you know when you're mad you bang gears like an idiot. And I ended up banging into second, and then going into third the shifter went floppy and I was like hmm I think the little cable popped off so I decide to drop into second and pull it off the road only to find that I can't take it out of second so it stalls in the parking lot of a close bank. I look under the hood and both cables are still in place and I can take it in and out of gear from under the hood. But the lever itself was only able to just flop back and forth from 1st to second.
Anyway do you guys think it's the actual stick or the cables? And if so how much do you think GM would charge to replace? Not under warranty anymore.
