Two weeks ago got a sonic 1.4T with the 6 speed... When i accelerate fairly hard and pretty firmly shift 1-2 at about 5-6,000 RPM it slips past the syncors and kinds for about .5-1 seconds then goes into gear... Same RPM yet with allot more pressure on the 2-3 and 3-4 shifts and it will not grind..
Any one have this happen... I have felt this on older cars nut mine only has 1,000 miles....
Thank YOU for anyone that helps out yah or neh
CREDIT PRELOADER.
So, just to bring this thread back into alignment, we found long ago that if you do the shifter cable alignment via the bulletin posted waaaaaay back in this thread, and drain and refill your m32 with 2.5 qts of a heavier synthetic such as Redline GL 4 75w-90, or equivalent, the 2nd gear grind should be remedied.
CREDIT PRELOADER.
