Go Back   Chevy Sonic Owners Forum > Chevy Sonic: Technical > Transmission Discussion
Like Tree132Likes
Reply
Old 09-02-2016, 12:52 AM   #501
Senior Member
Garage
Default
Mine did it today at like 4k rpm i was so confused. Granted i romoed first with traction on and went into 2nd quicjer than usual, but thr gring doesnt usually occur until 4500 or 5k and you gotta be on it hard.
Anyone with the trans mount mod, does it help? Shifter bushings, shirt throw, any remidies? I have an extended warranty so im leary to throw the redline in
__________________
Im the drunk ahole on the forum
14 RS manual- Zspec wheels, MFab intake, Zzp highflow catback RS muffler, Camaro Brake Swap, full LED/ ZXE swap, Rokblokz mudflaps, plenty of vinyls and spray paint to go around.
02 S10 2.2 turbo. Please don't ask why.
minitrucking02 is offline   Reply With Quote
Old 01-17-2017, 04:31 AM   #502
Senior Member
Garage
Default
I'm at 43k miles on my RS manual and just replaced the factory fluid with 2.5qts of Amsoil Synchromesh and my 1-2 grind is gone. The actual rowing of the gears feels about the same but after warming up 5+6 gear are very easy to get into, flies in like butter.
Overall definitely worth changing it out if you can DIY it as its only $40 for the oil and maybe $20 In tools if you don't have any.
On my 2013 I used a 10mm long L-shaped hex Allen key to undo the drain bolt and a 8mm hex socket to undo the fill port. Took maybe 20 minutes. I didn't get to measure how much was drained but I believe it was under 2qts. Filled her up with 2.5qt.
Sent from my SM-G925T using Tapatalk
$ub$onic likes this.
__________________
13 Sonic RS | Summit White
cuartz7o is online now   Reply With Quote
Old 01-18-2017, 12:04 AM   #503
The Sticker Guy
$ub$onic's Avatar
Garage
Default
I can get AMSOIL oil for anyone looking for some
Sent from my S60 using Tapatalk
pbkn1p likes this.
__________________
2012 LS 1.8 track car
2012 LTZ turbo daily
2015 LTZ turbo
interested in AMSOIL?
http://www.snailwerksracing.com/amsoil.html
I get all my parts from Bad News Racing- Click their logo to check them out!
$ub$onic is offline   Reply With Quote
Old 05-19-2017, 03:09 PM   #504
mja
Senior Member
mja's Avatar
Garage
Default
The difference between 2012 and mid-2013 MY's shifters were noted earlier, here's the instructions for newer 6MT's. See post #396 of this thread for a picture of the newer shift tower.
1. Remove the floor console. Refer to Front Floor Console Replacement.
2. Lift upward and disengage (do not remove) both cable lock adjusters (1) to release the internal cable assembly, one for each side.
3. Block the shift control housing, push the selector lever (2) backwards and push (arrow) the blocking device (1) towards the shift control housing.
Note:
The hole of the transmission gear control (2) must be aligned to the hole in the base so the pin (1) can pass thru both. The transmission gear control will be locked in the 1? neutral position.
4. lock the position of the shift control lever by rotating the reverse lockout device with the following instructions:
Push down on tab (1) and pull up on device (2) to release from installed position.
Rotate device 180 degrees so tab (1) is in the rear of the shift control assembly.
Secure integral pins (4) in holes located on shifter base by pushing down device (2).
5. Secure adjuster locks (3) by pushing down until locked. One for each cable.
Note:
During this procedure DO NOT touch or preload the fixed shift lever as this may cause mis-adjustment to the shift system.
6. Reposition the reverse lockout device with the following instructions:
Rotate device (2) 180 degrees so tab (1) is in the front of the shift control assembly.
Push downward on the reverse lockout device (2) until tab (1) snaps into detent
Note:
When unblocking the blocking device (1) a defined snap noise should be audible, a snap effect should be felt.
7. Unblock the shift control housing, push slightly the selector lever (2) backwards and pull (arrow) the blocking device away from the shift control housing.
8. Install the floor console. Refer to Front Floor Console Replacement.
9. Verify correct operation of the transmission control assembly.
__________________
2012 Sonic HB LT, 1.4T 6MT
The build thread
mja is offline   Reply With Quote
Old 08-16-2017, 11:59 AM   #505
Senior Member
Garage
Default
Anyone else out there made the oil switch, re-adjusted the cables, and still have the problem?
__________________
Turbo Hatch
To Many Mods....
Build Thread
Big Turbo Sonic is online now   Reply With Quote
Old 08-16-2017, 02:28 PM   #506
Senior Member
Garage
Default
Quote:
I only changed the oil and it helped but can still happen if Im careless. Have you looked at the CDV delete option?
__________________
Old 08-16-2017, 10:39 PM   #507
Senior Member
Garage
Default
I dont even know what that stands for. Please explain!
__________________
Turbo Hatch
To Many Mods....
Build Thread
Old 08-17-2017, 12:42 AM   #508
Senior Member
Garage
Default
Clutch delay valve delete for the m32 6 speed. I've seen it done on the cruze forum not on the sonic forum. There's a video of the 5 min process on youtube but I have not tried it on my car yet (or even located the valve yet). I would try it though since it's reversible.
https://youtu.be/UEbY-WPMljY
__________________
Old 08-17-2017, 01:22 AM   #509
Boy-Dirt-Car's Avatar
Default
In the Instructions that mja posted:
"The hole of the transmission gear control (2) must be aligned to the hole in the base so the pin (1) can pass thru both."
What Pin?
#(1) in the picture is the tab that releases the shifter shaft.
/me=Confused
Boy-Dirt-Car is offline   Reply With Quote
Old 08-17-2017, 02:57 AM   #510
Senior Member
Garage
Default
What Pin?
/me=Confused
Yea doing this mod /fix was hard for me to follow so I have not tried to. I know others have, hopefully someone can chime in
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
