re: manual mode
just recently acquired a new 2012 silver grey sonic ls. First things first, the manual mode isn't a gimmick on this car; unless you are on a proper decline the engine will refuse to kick out of 4th gear, so using manual allows you to do so even at around 1500rpm in 4th gear. If you have the patience to learn how to use it it will both help you on fuel economy, and as long as you aren't sprinting from a stop in 1st gear. Manual mode actually offers quite a bit more performance versus being in auto mode. That being said, the time between shifts on the manual mode is about 3 times that of in the automatic mode, but if you get the hang of it, hitting + at 5800 so it will kick over around 6200 ( full throttle ) you can get a decent amount of whiplash from that car. You should test drive it yourself so you can understand wholly what it is capable of, but just remember it was designed as an entry level car, and a gas miser.
