so I have had my trans mount in about a week now on my hatch. only times I have problems with the vibrations is at an idle. well a couple days ago my ac went out and I was stuck with the windows down and no ac. I had no vibrations with the ac off.. so that got me curious. I then removed my ultragauge from the car that only reads boost the whole time( does not show inches of vacuum). in the ultra gauges place I made a new mount for my galaxy note and began using torque with my Bluetooth dongle. I start looking at the vacuum pressures at idle with and without the ac on. at idle without ac my car is at 17 inches of idle, a bit less than it technically should be. when I turned on the ac the gauge said I went down to 10 inches, if that is true it sounds like I have a vacuum leak, the vibes I am feeling could be worse than the mount.
does any one have any ideas or advice on this? I know you should be around 20 inches at idle
