sonic24740
Zippy
I went and got a new bit.. lowes it was 18.00 and it had a pilot tip on it..
and spraying with lube will increase bit life..
Installed! Now it didn't go in as smoothly as hoped... Burned out a couple bits, one of the holes I drilled was at the wrong angle... Also its really hard to get leverage drilling off your back, on said angle.
But its finally in, and I know Ill just be repeating what everyone else is saying but WOW!
With decent tires (and TC fully off) its like riding on rails. Combined with the RS dampers and Eibach springs it feels like a big go kart, you just point it in the direction you want and it goes. I have yet to find its limit, but it begs to be run through a slalom. Ride is definitely a little harsher, but not much worse than what you would have if you put in different springs (might be compounded by the fact my car is lowered).
i also found it easiest to start drilling at what ever angle was the easiest or gave me the most control. Then once i'd gone in enough to not worry about the bit to walk i'd change the angle to be with the centerline of the torsion beam.
When we have been drilling the holes here we make sure to use lots of lubrication on the bit, Kroil is our favorite, although no stores sell it, only available by ordering direct from the company. Fantastic stuff by the way, excellent at penetrating rusted bolts, along with lubricating on drilling.
I second that. I have a bunch at work. May have to get some for this job. If you can use it well use it the best out there
It's my understanding that this car might not need this rear brace. I'm completely stock as far as tires and suspension. Going down some windy fun back roads. The back end of the car likes to come out a lot. Wouldn't this bar like all other bars of this type just make the car want to oversteer more
Anybody getting some creaking sounds from there brace?
It not like I don't want to get the peddlers. I simply do not have the money.
But for less then 400 I have a car that handles great on the street. Would peddlers make it better? Absolutely! But it's what I got.
