I've had my sonic for just over a month now, and am at just under 2k miles. I haven't notice any issues with the car, and have enjoyed driving it. I don't abuse the car at all, though I drive about 80 on the highway, I accelerate to that speed pretty gently and gradually. The only issue I've had prior to tonight is the brakes haven't been consistent, despite even pressure on the brake, they seem to grab either too vigorously or not quite enough for the amount of pressure being applies. It's cause quite a few uncomfortable "lock-ups" with the brakes
This evening a whole new problem arose.
I was leaving work and was doing about 30mph, and my engine started to whine as if under load (1.8L Auto) and then I felt it upshift. When it upshifted I let off the gas. Unfortunately I continued to accelerate despite being off the gas. It upshifted again, my speed was now 45. I started to apply the brake, and nothing happened. I did stop accelerating, but I wasn't slowing down.
A coworker ahead of me stopped to let another person turn in, and I start pumping my brakes to no avail.
I ended up using my ebrake to stop. After everyone was safely ahead of me I put on my hazards and let off the ebrake. No movement. I give it a little gas and it sluggishly responds and I slowly roll ahead. I begin to pull over and then the car dropped into Neutral, and then reverse while I continued to coast forward to a safe area in which to stop.
I put it in park, felt the gear change and shut off the car for about 30 seconds. I restarted the car, shifted through the gears and waited to make sure everthing was engaging, and it was. I took a loop around the facility and everything seemed fine.
At no point did I have any warning lights come on. I drove home as if nothing had happened after that.
I'll be calling the dealership in the morning, but after this incident I'm terrified to drive the car.
Any thoughts on what could have caused this?
