1-2 shift grinding status
Status
Not open for further replies.
klystron
Banned
After the new transmission went in and nothing changed, the fixed operations manager at Premier Chevrolet in Morgantown, WV drove a brand new Sonic in sales and was unable to reproduce the problem. He talked to engineering and they have sent a whole new shifter assembly with new cables and everything as well as a new "custom spec" transmission whatever that means.
Hopefully more news to report next week.
brandon1239
klystron
Banned
I have the same issues. There's a sticky thread in the Transmission forum here: http://www.sonicownersforum.com/for...sion/2626-second-gear-grinding-remedy-35.html
So far they are replacing the clutch, presure plate, shifter, linkage, and hydraulics. The "hand-built transmission" that was ordered was put on hold. The good news is that my dealership is working with a GM engineer who is very much interested in solving this problem. This could mean that a solution for others who have this issue is on the way. I will know in the next day or so if I am going to get a 3rd transmission. It's unlikely, however.
I am very lucky my dealer was willing to test drive two new cars to check for this issue. I know normally you don't do a hard shift on a new car but they wanted to see if they had an issue and they did not. Mine did this from day one. I am really happy with Premier in Morgantown, WV.
I have a phat Impala until Wednesday.:blankface:
rcmn0022
klystron
Banned
Mine went away but I had this issue when my car was new.
It seems like this was the transmission maybe breaking in the synchros or something but it hard shifts like a dream. I was even able to NLS through all the gears, the 1-2 shift works perfectly now.
Try quickly shifting and see if this slowly solves itself, at least that was my case. It could be a different cause of the issue for the two of us.
I'm not sure I want to grind my gears into submission. :) Thanks for the info, though.
rcmn0022
OD3X1
rcmn0022
RaceThisLTZ
OD3X1
Preloader
The M32 Martyr
theenico
Status
