SuperS13
Sonic86
Hey guys, gonna be working on cv axles, got a 1.8L with 6t40 6spd automatic transmission. The Driver side has out cv joint boot ripped to hell. Any tips and tricks on getting the old cv axle out and putting in the new cv axle. I saw you need to be careful with the trans outer shaft seal and gentle with that outer flat gasket that gets squashed by the hub. I also got the cv shaft pickle forks to ease the job. Problem is I have 78k miles and I know the cv axles start to go around 75k miles, should I just bite the bullet and install the cv axles? Any tips and trick would be appreciated thanks
