Immortal Panda
Recently got a zzp tune and started getting p0300 and the stabilitrak flashing. It is very annoying because it is random it will run fine and shift fine sometimes. Anything but WOT will run as expected but WOT it will randomly miss between 5100 up to 6200 rpms. Sounds like an A10 warthog
. Have used hptuner to scan with stock coil pack and zzp coil pack. Tried plug gap .026,.025,.024,.023,.022 all misfired at the same range new plugs tried same gaps no change. I need any help I can get to fix this please. I almost became a semi trucks hood ornament because it started to misfire and wouldn't shift or accelerate had to let off. Needless to say I could have cracked a walnut with that clench
Injen CAI
Mamba waste gate 14.5 psi spring
Zzp 2.5 in cat back
Zzp coil pack
Zzp pcv fix with catchcan
Ported intake manifold
Zzp full intercooler kit with throttle spacer and larger throttle body
Injen CAI
Zzp 2.5 in cat back
Zzp coil pack
