Hi all,
I now make a fitting to change out the 2 plastic connectors that connect the outlet tee to the expansion tank. Even if you change to the ZZP or Mitzone aluminum outlet tee (and you should) then you are still left with the little plastic fittings which often break and leave you stranded.
I have tested this solution for about 100,000 miles on my Chevy Cruze and it has been bulletproof.
I can sell these for $30 plus $6 shipping for the straight fitting to US destinations and $31 for the 90 degree hose barb version.
