Check this out. SECOND TIME DOING THIS. Just wanted to share:
BRAKE PADS - 2016 cadillac ATS - PN: your choice of whatever brand you want. i went with Detroit axle or go ask your local autozone
ROTORS are from a 2016 Buick Cascada - PN FW879FX - 321mm MUST BE THIS!!! otherwise WONT WORK WITH ATS ROTORS. ASK ME HOW I KNOW LOL
CALIPERS are from a 2016 Cadillac ATS - PN 84544154 & 84544155
STAINLESS STEEL BRAKE LINES:
zzperformance.com
WHEEL HUB / BEARINGS:
zzperformance.com
EXTENDED WHEEL STUDS:
zzperformance.com
WHEEL SPACERS (10mm): x4 (front and back)
zzperformance.com
NOTE:
I ordered custom cut vinyl stickers from my local vinyl cut shop for 4" SONIC logo decals and the BREMBO from online ebay shop. i used the small brembo logo from the original cadillac stickers lol. but anyway, also used VHT (very high temp) paint from autozone . sanded / cleaned / primer / red / vinnyl / clear coat to top off vinyl to prevent from peeling off.
My first time around on my 2015 sonic (RIP) i used 20mm spacers / bolt pattern converters so that way i only had to drill the rotors since the bolts werent long enough but that added A LOT more weight to the rotational mass thus - my TRANSMISSION sort of blew - anytime i would go in reverse there was a LOUD clunk noise and also anytime i let off clutch it was also a bit loud... sort of like an axel breaking of sort.. the car was 1000% still drivable though just thought that since i pushed my car to 250whp i knew i was breaking something LOL. anyway... this is my second go around... will post pics if anyone is interested. cheers.
Goodridge Stainless Front Brake Lines - Sonic
This is a pair of front brake lines for your Cruze/Sonic. DOT approved.
zzperformance.com
ZZP Wheel Bearings - Sonic
These are ZZP replacement wheel bearing and hub assemblies for your Chevrolet Sonic. Our hubs are backed by our ZZP 2 year warranty. Front includes captured wheel bearing and hub. These hubs will need to be pressed into your stock knuckle as they are not a sealed bearing like the rear. Rear...
zzperformance.com
ZZP Wheel Studs - M12 x 1.5
Our ZZP wheel studs are constructed of high tensile strength chromoly steel to ensure proper clamping force and longevity. These studs are extended length over stock for those needing extra thread from wheel spacers or wheel design. Studs are approximately 1" longer than stock. Total threaded...
zzperformance.com
ZZP Wheel Spacers
SOLD IN PAIRS Dial in your wheel fitment with our ZZPerformance wheel spacers. Our wheel spacers are CNC machined out of aluminum with hubcentric centers for many of our specific platform vehicles. These spacers are an exact fit for our platforms and ensure worry free usage. Available in...
zzperformance.com
NOTE:
