Corvette c4 wheels sonic #2
Sup errbody
I contacted Andrew GS and matched his set up with the only difference in tire width and coil overs
You will need
2 separate front sets of corvette rims
Motorsport Techniques billet aluminum adapters 265.00 @ 25mm thick
To convert bolt pattern
Andrew GS former sonic had 225 45 17
Recommend 235 45 r17 or slimmer if you want a drop your sonic.
My setup has 245 45 17 but is maxed out stiff to prevent rubbing of fender
The 245 has better traction and the 1 inch adapters widen the track by two inches. = lower center of gravity and 4 inches of tire width equals monster grip
Stock LTZ hatchback pulls .81 lateral G’s
My sonic pulls of 1 G of force= turn fighter
This setup will give you the SHAKES and easily double the speed limits on highway exits.
Drive safe and stay thirsty my friends
