Yes, the seat back cover can be replaced separately on your 2016 Chevy Sonic driver seat. You’ll need to remove the seat from the car first, then take off the trim panels and unhook the seat back cover from the frame. The cover is usually held on with clips, hog rings, and listing wires, so it has to be pulled off the foam and then the new GM cover is installed the same way. Make sure to disconnect the battery before starting since there may be a side airbag in the seat. If you’re not comfortable doing that part, an upholstery shop can swap just the cover without replacing the foam.I searched a few terms but didn’t see a thread dedicated to 2024 polaris rzr xp 4 1000 ultimate accessories. Does anybody know how to replace the back seat cover on the front driver’s seat back? Looks like GM sells the covers. There’s nothing wrong with the foam cushion itself, just the cover has a hole or rip in it.
