RockTheShazbot
DISCLAIMER: I am not responsible for any damage cause to your vehicle. If you don't feel comfortable doing the DIY shown below, then take it to someone you trust to work on your vehicle.
Difficulty: Easy
Time: 10-15 minutes
This install is for a manual transmission Sonic. The only difference is one less pedal on the auto.
First, take off the rubber brake and clutch pedal covers (just brake on the auto). No need to remove anything from the accelerator.
Notice the hook on the bottom of the accelerator pedal cover.
Hook the...hook to the bottom of the pedal (make sure it is hooked on. If it gets bent, just bend it back into place, the metal is really soft.)
Repeat this process with the brake and clutch (if applicable)
All done!
Difficulty: Easy
Time: 10-15 minutes
All done!
