My auto will rev just under 3k, but 2900rmp. Don't do this with the wheel turned, learned the hard way.....Don't ever pull the ABS fuse in the automatic sonic's if you want to make use of the car's launch control feature. It's actually built in to the ABS system on the automatic transmission sonic's and if you pull the abs fuse you won't be able to use. I know because I've tried it already. The pulling the ABS fuse option is best reserved for the manual transmission sonic's.
All you need to do is listed below.
1. Hold the T/C button down for 10 seconds to disable the stabilitrak system
2. Apply firm pressure to the brakes and hold the gas down at the same time.
3. Release the brake pedal when it's time to launch.
You should have a 2500RPM torque converter stall at around 10psi. Do not do this for more than 5 seconds because this is very hard on the the whole driveline.
No the efi live does not disable anything on trans. Just push tc button once and dissable tc. Dont worry about st, it will only activate if you go sideways, believe me i know. I have done everything you can imagine exept put it on the roof lol
