Smashley23
If you could choose 2 parts that you wish were made for the sonic, what would they be?
opcorn:
To clarify my fuel system request, we need a fuel pump and a fuel pump driver module tune or modification. I’m sure that ZZP is well aware, but we can’t just drop a fuel pump upgrade in there. The ECU is going to need some adjustment. Thanks so much for looking into the wants and needs of the Sonic owners.
Nat, I think RacerX might be close to a solution on the fuel pump front, they are currently testing there car with the fuel pump hanger(w/ 3 diff pump sizes and make it a return system) they made with diff pump/60# injectors plus CAI & ITM they have before they drop there turbo/mani in to test. So i am curious as to what they plan to do, tune the exist if possible OR add a new FP module.
Ya, a fix for the valve cover might be nice.. billet is out of the question as that would cost a perty penny(would def be well over 1k), but maybe a cast alumi (might be cheaper then billet) one with a replaceable pressure regulator diaphragm.
That’s why I’m asking questions. If there’s tuning available already, then great. If the CELs can be switched off while still showing as ready, that’s great too. I’d have no issues if those things worked in the software used for my tune. I’m being tuned by BNR with EFI Live, so I’m not sure if it can do those things the same way as HP Tuners.
Yep, feel free to pick my brain too if you'd like. Don't think of EFILive or HPTuners as anything more than a tool. They can be used with great success with quality calibrators like Jerry at BNR, or botch a tune if a "tooner" gets ahold of your car and don't know what they're doing. All these tools allow is access to different parameters and tables in the ECM (and TCM) code, as they're different companies not all tables/parameters exist in both suites. For the Sonic, HPTuners has more parameters available, but that's not always a good thing. Most calibrators, even on a crazy big turbo setup, have no need to adjust half of them. I can't speak for what or how BNR is creating their tunes, maybe it's worth asking?
Most shops use a combination of both tuning suites (BNR sold HPTuners for a while as well). The benefit of EFILive is the AutoCal which enables remote tuning. HPTuners doesnt have as elegant of a solution as the AutoCal for sending tunes + logs back and forth.
I'm doing 42lb injectors next month (and intake manifold, WGA, handful more things) and will be tuning the FSCM, I should probably start a thread on this...
About the HP tuners and not being able to do remote tunes is untrue. We use HP tuners daily. It is JUST AS EASY as any of the others. You still have to load your file then transfer to your car. Why do you think that about HP tuners? I am totally lost on your thought about them. Have you used one or is this what you think?
