I heard people were having issues with this. The only thing Im thinking you can do is to cut the factory speaker wire, mount a new speaker under the dash, then connect this wire to that speaker. Then you can run a wire from your new front door speaker to your 6 channel and presto...no more loud noises. Your new speaker will be amplified and you wont lose out on your warning chimes. Cheers.
