Hope I posted in the right place this will be a little longer post. So I've had some creaking and eventually a popping when turning right. So first I did with help quick struts from autozone while it helped it didn't fix my popping. Got it diagnosed said lower control arms so I got duralast lower control arms with ball joints. I put them in had to take out the strut bolts so I could lift the hub/rotor area and slide everything in. After completion I drove it thought I heard maybe something small but dismissed it my right turn popping had completely vanished. Other than that on my short test drive I was overall pleased my ride quality improved immensely. I got it alighned at firestone drove it home and heard a pop this time on the left. Fast forward after driving it I've noticed it will pop on both sides mostly when rocking doesn't have to be a turn. It's done it braking and accelerating typically at a angle or maybe slight turn. I did try to pre load the bushings by lowering the car with the tires on onto some bricks about 6inches high give or take a inch or 2 then fully tightening. Other new parts in the last 6 months include sway bar links and outer tie rod ends. Any ideas would be appreciated 1.8L 2018
