Swordsmith
242hp/252 ft-lbs BNR EFI
Installed the new clutch and flywheel from Clutchmasters this weekend.
Basic order of operations:
Remove battery box and starter
Disconnect all electric cables to transmission
Drain coolant
Remove heater core hoses
Disconnect Vacc hose to brake booster
Disconnect evap line to fuel on top of intake.
Disconnect fuel line (not needed on my install since my alcohol sensor add on made the lines long enough to stretch)
Remove transaxles
Remove rear transmission mount
Support radiator
Remove subframe
Support engine (note hammers used to prevent support from crushing car)
Remove port transmission mount
Disconnect slave cylinder hose
Lower engine leaving starboard side up, low enough to get clearance to remove transmission
Dismantle transmission
Remove clutch and flywheel
Fit new clutch and flywheel; note, works in only one of the six possible positions.
Bleed clutch. Note, prebleeding helps a lot here.
Reverse above order of operations
I think I have pics of most of the above, going to start sorting them and will edit into the post.
Drain coolant
Remove transaxles
Support radiator
Remove subframe
