To answer your question, I say "man, I keep forgetting to put electrical tape over that light"... if I say anything at all. Mostly I have learned to ignore it so completely I don't even see it.
The other thing I say is "Why can't they put a light there that tells me which gear I am currently in, instead of that lame shift thing"
The light does not tell you when you should shift if you want to max out power, it is very very early. It does not tell you when to shift if you want to max out economy; depending on terrain it is usually a bit late but sometimes still early, and only right in the same sense that a stopped watch is right twice a day. In short, it is relatively useless, unless you are new to driving an MT, in which case it is a fairly safe middle of the road suggestion of shift point which leans a bit towards economical driving.
I keep hoping Vince figures out how to reprogram it and offers that as a part of the Trifeca tune, in the same way he reprograms the shift points of the automatic. I would love to have that little light be actually useful, even better, to have it switchable along with selectatune, so that in power mode it suggests shifting up around 5500 rpm and in eco mode it suggests shifting down around 1800. Still would be non optimal (since actual shift points still vary based on conditions), but would be closer to useful and serve as a reminder if I was waiting too long.
Or just tell me what gear I'm in, I know this sounds crazy but I shift into neutral and back into first a lot more often than you'd think, because I am often not quite sure if I'm in first or third, when suffering through some stop and go.
