SuperS13
Sonic86
So have a problem with my 1.8L, I even have a new dorman radiator fan unit. Where would the relay be for the radiator fan assembly and the coolant temp sensor relay? I've heard there is a certain relay that you need to replace if it's not the hi/lo fan relay. I've directly used wires to see if the fan worked all good there. And I've used a multimeter and found no wiring issues.
