ahtoxa
How many of you guys have used SGII to measure your 0-60?
I did a few runs today and my fastest was 8.8 seconds which is a bit slow (6MT HB).
Weather: 60* and 91% humidity with very light drizzle. Roads were dry. Grip was fine.
Knowing that the 1.4T has been clocked at just under 8 sec on 0-60, could the high humidity have that much of an affect? I was also monitoring boost levels and found that they varied per run. Highest I got on one run was 18.5 PSI and highest on another run a minute apart was about 16.7 PSI.
For those that have used it, what were your times and do you think SGII is accurate enough?
EDIT: I did have to pause for just a split second with 1-2 shift to avoid the grind. Perhaps if I slammed second I'd gotten a bit quicker times.
