jeff@racerxfab
Supporting Vendor
Well it looks like we lucked out and were able to move forward with a few more products. After we installed the GT28 turbo on our sonic we had the worst experience with engine rotation under load. It was to the point where the engine would move enough for the exhaust system to contact the subframe. However we are not keen on engine mounts as they usually increase noise and vibration into the cabin. We moved forward with building an engine brace to prevent or drastically reduce the rotation. We CNC machined a mount from 6061-T6 aluminum and then we designed a bracket for the subframe that is CNC lasered and formed. Finally we added the brace to connect the two points. The result is an engine brace that works very well and transmits little to no vibration or noise into the cabin. The sonic now unleashes the power like never before!!
Check it out here: https://racerxfabrication.com/sonic/misc/engine-rotation-delete
Few pics of the kit:
