MacGregor
Calling for your expertise! I have never driven a turbo engine car. IF Sonic is offered with heated seats AND a non-turbo engine, I will buy one. However, my hunch is that GM will market the Turbo on the high-end heated seats Sonics. Typical GM marketing ploy: Appeal to the Ignorant Buyer! Get MORE money out of the buyer, both when he buys the Turbo and when he takes it to the dealer for maintenance!
I can understand a Turbo on a diesel engine; WHY on a gasoline engine?
Cons against Turbo:
Lower fuel mileage (mpg).
Turbo Lag while accelerating. No Low End Grunt entering Freeway. Annoying.
More moving parts = more things to break and expensive to maintain.
Turbochargers can be damaged by dirty or ineffective oiling systems. Manufacturers recommend more frequent oil changes for turbocharged engines.
May burn oil.
Price.
Pros in favor of Turbo:
Added power comes at high RPMs, when engine is putting out enough exhaust to drive the fan quickly enough to supply the extra air (Speeding tickets?).
Better performance at high elevations, such as Colorado Rockies.
You get a little plate on the rear deck that says “Turbo.”
Turbos are “Kewl.”
Owners have “Bragging Rights.”
Girls think turbo drivers are Macho.
Turbos are Desired by Teenboyz.
Turbo Lag
Turbo lag is the time required to change speed. This is noticed as hesitation in response when accelerating from idle, compared to naturally aspirated engine. Throttle lag is noticeable under any driving condition and becomes a significant issue under acceleration. This is because time is needed for the exhaust system working with the turbine to generate enough extra power to accelerate rapidly.
Because the turbocharger heats-up when running, letting the engine idle for three minutes before shutting it off gives the oil time to cool the turbo rotating assembly, and ensures oil is supplied to the turbocharger while the turbine housing and exhaust manifold are still very hot; otherwise lubricating oil can be trapped in the unit and the heat soaks into the bearings, causing rapid bearing wear and failure when the car is restarted. Even small particles of burnt oil will accumulate and lead to choking the oil supply and failure. A turbo timer can keep an engine running for a pre-specified period of time, to automatically assure the cool-down period.
Cons against Turbo:
May burn oil.
Price.
Turbos are “Kewl.”
Turbo Lag
