RichieRocket
Continuing the discussion over here from the DIY forum...
Anybody find anything interesting?
The catalytic converter temp got up to 1300F today...
I've been messing around with the UG set-up.
- Set Engine size: 1.36 L
- Confirmed that the Sonic uses MAF Mass Air Flow
- I was getting the Voltage MAX alarm at 14.9 Volts so I bumped that alarm up to 15V
- I reset the page refresh rate to every 0.5 sec (default is 1.0 sec) Hopefully that will smooth out the turbo boost reading a little.
I wanted to "Calibrate Distance" as described on page 38. So I decided to head over to my local interstate and do a 5 mile drive to calibrate to the mile markers. Well there weren't any mile markers! LOL
About ten years ago, there was a big construction project that widened the interstate to three lanes and never re-installed the mile markers!
As BNRacing said, the Torque and HP values are calculated from engine parameters. They not real numbers but maybe could be used for comaprisons.
The max torque has to be set per page 39
