Swordsmith
242hp/252 ft-lbs BNR EFI
I recently saw a discussion about "snow" tires which contradicted my old common sense understanding of how they work and who should use them.
I thought the difference between summer, winter, and "all season" tires was in the tread; that a rougher tread would give better traction on slippery roads but a worse ride on dry ones, and that therefore you would ideally want "snow" tires only if you were seeing so much snow so often that it was worth the sacrifice.
I also thought "summer" tires were simply worse traction cheap tires that you could use for a comfy ride to spare the tread on your winter tires... but that what you really wanted to do was upgrade those to "all season" tires because even in summer you could see rain or mud and would want the added traction, it was worth the expense.
If, I assumed, you had all seasons, you were better off than with plain old summers, and nearly as good in occaisional snow conditions as if you had dedicated snow tires.
OK, so that's what I thought was going on. Here's the spin they were talking about though: Tire rubber functions well in a relatively narrow heat band. Summer tires work well when it's hot out, giving better traction and handling even when it's rainy than either snow tires Or "all season". Meanwhile "snow" tires, which they suggest should be called "winter" because "snow" is misleading, perform badly when it is hot out, but work well when the weather is cold. And All Seasons have no functional heat band, and perform really well never, perhaps, according to this source, they should be called "no seasons"
I have the stock wheels, with the stock Hankooks on them, and I have some custom wheels with some all season aftermarket tires. Now the Hankooks were outright bad in cold conditions, but it's possible I've been dissing them unnecessarily, perhaps they work great when it's hot out; I bought my car in the fall and had them off within a month. And I've never owned snow tires, because I've never really seen more than a handful of days of snow each year, at least until this year, so I have no basis for comparison.
Seriously considering scrapping both sets of tires and getting two sets, though, based on this discussion. Any thoughts?
Helps that this year I have seen more cold days and more snow days than I have in probably the last five years combined... so I am thinking more about what it is like. But these guys were saying that the snow part isn't really important, that I'll get bettter performance even on dry days from the winter tires, when it's not hot out.
