Dave@ddmworks
Supporting Vendor
Another project we are back at is the intercooler development. We started back at it last weekend and wanted to get some baseline numbers on our test car. The test car has a DDMWorks intake, DDMworks prototype exhaust and tune on it while doing this testing along with a ported intake manifold.
We tested 2 cores and had some unexpected results.
The 2 cores that we tested were -
22" x 7" x 2.5"
24" x 6" x 2.5"
Both of them had cast end tanks, bar and plate design with aluminum charge tubes 2.25" in diameter used on both intercoolers for testing from the turbo outlet to the throttle body.
The dyno below shows the stock intercooler in blue
The 22 x 7 x 2.5 in green
The 24 x 6 x 2.5 in purple
We were a little amazed that the stock intercooler was holding up so well against the larger aluminum ones. So we tested how the different intercoolers flowed and found that the 22 x 7 x 2.5 flowed better then the stock intercooler, the 24 x 6 x 2.5 actually flowed worse then the stock intercooler. So we are going to do some more testing to see what is actually causing the loss of power we are seeing with those intercoollers. We are also having a custom intercooler made right now by the same company that makes the intercooler we use on the Solstice/Sky and will test that with the next batch of testing also.
22" x 7" x 2.5"
24" x 6" x 2.5"
