Go Back   Chevy Sonic Owners Forum > Chevy Sonic: Technical > Handling, Braking and Suspension Discussion
Like Tree8Likes
Reply
Old 12-07-2012, 07:05 PM   #41
The M32 Martyr
Preloader's Avatar
Default
So I paid more attention to my ding.
It's not in my head, it only happens about 1in 10 starts. Particularly the second start of the day after warm up. It's almost like more of a reminder, than a warning.
__________________
My Build: The Preloader™
Hardly Functional
Preloader is offline   Reply With Quote
Old 07-01-2017, 12:54 PM   #42
Senior Member
Llia's Avatar
Garage
Default
I'm going to pull my fuse. I tend to react/anticipate quicker than the stabilitrack anyways. I let off the throttle when I notice the slip then it decides to apply the brake after the fact and the car jolts really bad.
Syrup likes this.
Llia is offline   Reply With Quote
Old 11-14-2017, 02:35 AM   #43
Junior Member
Default
Does anyone know of a tuner that can modify the effect of the stabiltrak? I am having issues getting off of the line under heavy acceleration. The issue is simply one of being able to get out of the way rapidly if needed. I am new here but I sure could use some advise.
bsonicoregon is offline   Reply With Quote
Old 11-14-2017, 02:43 AM   #44
Senior Member
carsNskis's Avatar
Garage
Default
You can wire a switch to bypass the fuse. Have you tried holding the tc button for more than 8 secs? It mutes the tc quite a bit
carsNskis is offline   Reply With Quote
Old 11-14-2017, 03:13 AM   #45
Junior Member
Default
Thanks for the reply, had read that advice above and really was looking to tweak the cpu instead. I really appreciate the input
Last edited by bsonicoregon; 11-15-2017 at 05:00 AM. Reason: spelling correction and incomplete
Old 11-14-2017, 04:07 AM   #46
Senior Member
carsNskis's Avatar
Garage
Default
Quote:
Originally Posted by bsonicoregon View Post
Thanks for the reply, had read that advise above and really was looking to tweak the cpu instead.
If there's anyone I'd trust to do so it would be Jerry Kinney at BNR.
Blue Moon Sonic likes this.
Old 11-14-2017, 04:17 PM   #47
Senior Member
Blue Moon Sonic's Avatar
Garage
Default
For anyone who has an automatic. Don't pull the abs fuse unless you want to loose the hidden launch control feature. If you pull the fuse and go to do a boosted launch, it won't sit at 2k like if you held the button to disable it. even if it's a 1000rpm difference, that's enough of a difference to changes how the car launches.
__________________
In soviet russia, you don't choose the car you want to drive. The car chooses the driver.
12 chevy sonic 1.4T ltz - Back to Daily status(replacing transmission).
2008 Ford Mustang: Engine Swapped from a v6 Building for Pikes Peak in 3-4years. Need more funds and sponsors. -retired till spring
2006 AWD Pontiac Vibe - Retired for emergency use only. LS swap planned.
2012 VW Golf R 6spd manual -Stage 1. In storage till new tires go on. -driven until sonic is fixed
Blue Moon Sonic is online now   Reply With Quote
Old 11-15-2017, 05:02 AM   #48
Junior Member
Default
From what I have read on this forum in the last three years BNR would be my chip choice as well.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
