dvn
Just use a regular socket that fits it. That's what I did and I even have 2 sets of inverted torx socket sets.
8mm socket fits fine.
Just put the stock pipe back on That's what I'm doing next month. I'll let you know how it goes!
Thanks. I got it in!
Here's a few pics that may help someone else:
O2 sensor plug attached to blue wire
O2 sensor (right) and v-band bolt peeking out from under heat shield. My O2 sensor was on petty tight
Three 13mm bolts at rear of downpipe. I found a nasty dent in the exhaust down there too.
Lower mount bolt, 10mm Hidden bolt, also 10mm, is directly above that one, facing the front of the car. Just kinda follow that mounting bracket upwards and you should feel it. I used an offset box wrench to loosen it and for the first few turns then I switched to a 1/4" drive socket wrench with a tilting head.
