MyLonewolf25
Yes front arms
No idea, I run 3-3.5 degree
Sent from my S60 using Tapatalk
How harsh are they on road?
Yes front arms
Hard to tell exactly, the whole car just sucks to drive on the street with it being so stiffHow harsh are they on road?
Most of that can be helped with a good set of coiloversI was looking at them for mine but mines more DD than anything else
I just can't stand the sloppy rear and how much wheel hop there is( that and how understeery it is) it angers me irrationally
Has anyone tried this DIY? https://youtu.be/2_0BYvTkZ0o
Been behind schedule but I got the adapters made up today. I need to find some spacers for the new bearings as they are shorter overall than the stock pieces, if I can't buy some I will make them but it should be simple.
Did you happen to confirm whether the cobalt/ion bushings fit in these arms? They look extremely close, and they sell solid rubber cobalt/ion bushings. I'll see if my press tool fits them someday and/or if the part numbers match up.
Thanks,
-RuD
No they don't, the sonic arm has a much larger hole in it.
I made some spacer sleeves for the bushings and installed them in the sonic arms, I need to make some small sleeves for the bolts, as the sonic bushing is much longer in the center as well, just haven't been back to the shop.
My sonic is going in for a water pump tomorrow, maybe this weekend i'll go back to the shop. I thought I could simply buy some cheap spacers to save time, but it doesn't seem to be a readily available size.
Nobody?
I've been gone a while but what would the pricing on these be about?
