There are a lot of guys on here who have tuned in the past, currently tune, or datalog. To tell these people that KR comes on constantly is like
GM ECMs for the last few decades have all had multiple spark maps for low and high test gas. Ign retard on KR sensor isn't common unless WOT or high torque demand at low load.
& Jesus, the meth inj wouldnt cool the motor as this mod would cool down coolant slightly quicker. That would cool the combustion chamber or IAT if placed in or before charge tubes.
I don't think theres any other way for the PCM to gauge fuel grade than by probing the detonation threshold and monitoring for knock.
That has to be the explanation for improved fuel economy from using higher octane fuel.
We've switched back and forth many times, and the fuel economy trend is quite consistent.
This has to be a fairly detonation prone engine, being a port injected, turbocharged, relatively high static compression (for a turbocharged engine), high operating temps, with high weight loading for its displacement.
It also engages torque converter lockup quite early, which further increases engine loading.
Especially on 87 octane...
And wether they use three different timing tables, or they simply tune around the one optimized table by subtracting timing at load/speed ranges, based on previous trends needed to keep the KS quiet.
Once it establishes what's needed to do that, you won't get much KS activity.
