What would be the best way to do that?Great! Have you tracked your interpreted power output provided by the ECM algorithm? I am curious what power you are putting down at that PSI.
Also, if you can get 93, I would try it.
14 Sonic LT 1.8A MBM
Oh I actually have torque. That's how I was checking the boost levels. I'll give that a try later tonight and report back.Pick up a Wifi or Bluetooth OBDII data broadcaster. Then pick up DashCommand (iPhone) or Torque (Android) and run it through your phone. It works great!
I understand that part. However, everyone I've seen post about their tune has said that they've hit 20-22 psi. It didn't make sense to me that everyone else's vehicles would need 20-22psi to reach 180lb-ft whereas mine could do it with 16psi.Boost is simply a part of the overall power equation for our engines. If the ECM asks for (simple example) 180ft/lbs at 4000rpm and can deliver that with 16psi, it won't increase boost to 17psi.
Do you know what the PID is for the ECM estimated torque?Pick up a Wifi or Bluetooth OBDII data broadcaster. Then pick up DashCommand (iPhone) or Torque (Android) and run it through your phone. It works great!
2705 I believe.
Hm, I'm probably putting it in wrong. When I add a custom PID it's asking for OBD2 Mode and PID. Do I just put 2705 in?
