NewZJ
I Don't Know
I saw this post on the Cruze forum
#PIP5036: Possible Oil Consumption With Cracked Piston Or Pistons - (Jun 25, 2012)*
Subject:
Models:
2011 - 2013 Chevrolet Cruze, Sonic
1.4 LUJ
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
You may encounter a customer concern of oil consumption, blue smoke from the exhaust.
There may be oil in the intake and turbo ducts or no oil found in the intake system.
Verify that oil consumption is greater than 0.946 L (1 qt) in 3,200 km (2000 mi).
Recommendation/Instructions:
If all diagnostic have been followed without isolating the concern.
We need to remove the pistons to inspect for a crack piston or pistons at the ring land between the number 1 and 2 ring.
Replace the pistons as needed using the part numbers in the catalog.
Do not replace the engine for this unless the block is damaged which is not common.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
I had this issue on my sonic, the dealer replaced all the pistons and said the block and head wasn't affected. The dealership I went to had not encountered this issue when I dropped it off but when I picked it up they said they might have another sonic with the same issue that was just turned in.
I have only 15500 miles on my sonic.
They sent me this pic of the ring
Subject:
Models:
1.4 LUJ
Condition/Concern:
