mja
Site Supporter
Have you considered the F40?
It's a good suggestion. I believe it may bolt up to the 1.4, but has anyone done it? Everything I'm seeing on the net is hearsay.
A few problems with the F40 - its seems the 2006 variants had issues with the 5th gear &/or synchros. The trans was redesigned in 06/07 with a new gearset. The details of those changes aren't well documented, at least from what I could find. It's a low volume trans compared to the M32 so used ones are scarce. And within those variants, different engine families were used so the case/bellhousings may be different. I'm curious which Cruze's had the F40 trans, all I found online was 1.8 has MZ0, but some 1.8 Cruze's came with F40?
The average price that I've found is around 500-600$
MPG is 1st goal for me so the M32 is better. 3.35 final gear ratio can be fitted, with a number of different gearsets, parts, & used ones are dirt cheap. Cryo & shot-peening shafts/gearsets should be enough for a bit more strength. I've read the most common M32's fail point upon rebuild is from setting incorrect bearing preload, that and not changing gear oil regularly.
