MyLonewolf25
Running meth has a lot of risks.
If you're at WOT and run out, or the nozzle gets clogged, or a line comes loose, or anything else happens and it stops spraying, your motor is done.
Washer fluid is cheap
Do your lines correctly
Check every time you fill up for gas and if you're still paranoid add a sensor that will tell you when it's low
Also if you're putting this much into tuning it
Why not get a stand alone ecu at this point??
