Anyone know if it'd be possible to swap the rear drums out for discs from the Cruze?
The Cruze has a twist beam rear suspension like the Sonic (though some have Watts linkage and some don't) and some trims come with rear discs or rear drums.
Attached here are the two rear suspension diagrams for a 2011 Cruze. It looks like if you can easily swap from drums to discs, that it might be possible to take the rear discs from a Cruze and put them on a sonic.
With Drums
With Discs
(I only wish I had a rear suspension diagram for the Sonic to compare)
They are so similar it looks like the swap would be an easy bolt off, bolt on affair (from Cruze to Cruze). Remove all Drum parts down to the twist beam, put on caliper carrier, dust shield, hub, disc, caliper, and then connect everything back up (speed sensors, brake lines).
Does anyone know if the rear wheel hubs on the Sonic share the same part number as those on the Cruze. If so, that may be a big clue into whether these parts will swap out.
On a slightly related note, does anyone know the disc diameter in the front for both the Cruze and Sonic? If the Cruzes are bigger, that might open up the possibility of an OEM Big(ger) Brake Kit.
With Drums
With Discs
