Preloader
The M32 Martyr
I wish there was a straight forward answer to that. It will likely continue to smoke until all the residual oil is cleared from your Intercooler and charge piping.
Also, it may not solve the issue at all if that is not the culprit to begin with. Thus is the frustration of troubleshooting.
The best I can do is tell you what I would do, if I was in your situation. Start with anything you can that doesn't require spending money to chase a problem you haven't confirmed.
Again, it sounds most likely that it is a PCV issue.
First place to look to help confirm is the PCV entry into the cold side of the turbo compressor. Remove the air intake piping that goes to the top of the compressor and look down in there at the ~1" hole where the PCV enters the housing.
If you see evidence of large amounts of oil having poured down from that hole..... You are confirming a PCV issue. At that point, I'd be more inclined to assume the valve cover diaphragm is suspect.
