I would use a pc, but down here in ATL those are about as rare as a girl not being a mom by 16.![]()
Easier on the sedan though. It has a little more room to flow the bulge out.
Omg if the sonic was a 2 door my wife would kill me Cuz I would have it
I have been thinking about this for weeks. I was thinking of using styrofoam to shape the fenders and throwing fiberglass on it if I can even get the shape I want. A little grinding on the stock fenders, wheel spacers, bondo, primer, paint, done deal.
I wouldn't go to crazy with wheel spacers, More offset and back space on a wider wheel would be key in keeping the suspension in check and not killing the hub and studs.
But the foam and glass trick is the most widebody kits start in the first place.
INNOVATION!
Bingo bango, simple as that.....got it done yet? If you are serious about that, I've glasses over that pink insulation foam from home depot before. It works really well if you make molds off the foam, otherwise you will be adding GALLONS of bondo to get it even. Plus if you have molds, you can make more than just a one-off.
