Oh god Sub, let's not start hunting witches! Just kidding lol. I had to
Macehammer- despite appearances I am not being hostile, it is not that I dislike you........ It is my distaste in corrections with out any form of counter.
While I can understand you disagreeing with a post and requesting for some form of reputable/plausible backup; I trust you can also understand how that should not be neccesary until someone that KNOWS (or even suspects) a sourcable reason to counter. Furthermore I can comprehend your reflectance to immediately responding to a questionable post with loads if sources (because let's not forget using sources requires multiple reputable resources.)
In which case a dialogue of sources and reasoning would start. I trust you also understand that occasionally actual numbers backed data is unobtainable (top speed for a sonic of X config for example).
In this instance my limited reasoning was based off two once true but apparently outdated reasonings..... 1. Manuals have less power loss when crank HP is compared to wheel HP vs autos and 2. TCC lock up behavior.......... One of which I stated in my first "counter" if you will to Sub, which in my case was incorrect.
I believe you to be a logical individual.... While you aknowledge I have alot of knowledge, I also respect the fact that you have alot... I'm just saying that you giving just a tiny bit of it in a rebuttal would be valuable and Welcome!
Future reference- If you disagree with me, give me a reason why... At the very least I'll do some more research and at the least keep my mouth shut.
At the worst I'll get some sources and prove you wrong (another future reference, I take no pleasure in rubbing it in)
Either case we both come out wiser, as does anyone following! I believe in the saying "a wise man will learn from a fool, a fool can't learn from a wiseman"
So next time enlighten me! Or give me reason to enlighten myself. :cheers:
