$ub$onic
The Sticker Guy
This is a step by step on how to install the steering wheel adapter.
NOTE/DISCLAIMER: This WILL remove the AIR BAG. This can be dangerous. Wearing a seat belt is always a good choice, but consider it mandatory with this mod.
I or Bad news racing are not responsible for any Injures associated with this. ALWAYS WEAR YOUR SEAT BELT!
With that out of the way lets start !
1) We must remove the steering wheel. Please follow this thread steps 1-5
http://www.sonicownersforum.com/forum/do-yourself-articles/9529-diy-steering-wheel-install.html
2) Before removing the wheel, make sure it is centered and the wheel is straight. Then remove the wheel. You should see something like this.
note: I just cut the air bag wires off. I do not recommend this. *facepalm*
3) Plug in the supplied horn adapter.
4) Take the adapter and slid it on to the splines.
Note: May need to use some wd-40 to help it slide.
This is it fully slid on.
5) now you see this
Reapply the center bolt, loctite is not Necessary but would not hurt. I just snugged mine and it has been fine.
Last, install the wheel.
The wheel bolts do not need to be SUPER tight, this will strip out the holes. Get them good and snug. There are 6 bolts, it will not go anywhere.
Wheel recommendation:
350mm with a 2-3 inch dish is perfect for me.
Wheel in picture is a flat 320mm. Not recommended.
5) now you see this
