Nice, does the engine still take foreeeveer to rev down? That is one thing I cannot stand and hope a LWFW will fix some of it.
It helped a little. But the long rev down seems to be more a function of the throttle programming than the FW mass. But....... I do believe it's not quite as bad. Definitely not gone to the degree that it feels like a normal manual.
You can see in the video that it stops dropping at about 2,000 rpm and then slowly settles down to idle. Again, seems like programming to keep stability for the consumer that doesn't want one single stumble.
It's built in for emissions. It should be pretty easy to tune out though.
I don't think trifecta will do it.
Probably not, Vince wont mess with much when it comes to emissions hence why he gave the ability to turn off the rear O2 sensor as well as other monitors to the end user in EZ Flash. Scot or Morgan might be able to tell us if it's doable with their software (HP Tuner?).
Any news on the steel wheel?
How long till you can romp on the car with the new clutch?
Does the flywheel change the spool up or how fast you get through the gears?
